LumenAria 36-Inch 6000 Lumen LED Semi-Flush Mount with U-Clips
- Dimmable LED is now a lamping option for thousands of wall sconces, semi-flush bowls and flush-mount products offered by Justice Design. The light quality is warm (3000K) and truly stunning. They are dimmable down to 5 percent and work on a variety of dimmers, including standard electronic dimmers. Not only are these fixtures energy efficient, consuming the equivalent of a 75W incandescent bulb (1,000 initial lumens) per LED, but they are rated for 50,000 hours ? which means no more climbing ladders to change light bulbs! The LED engine comes standard with a 5 year warranty. - Color Rendering Index: 85 - Beam Spread: 120 - Total Wattage: 78 - Electrical: Input Frequency: 50-60 Hz. Power Consumption per Light Engine: 13W Dimming: Compatible with Incandescent / Triac or ELV Dimmers. Driver Efficiency: Greater than 80 percent - Illumination and Efficacy: Light Output Per Engine: 1000 Lumens (Initial) . Light Engine Efficacy: 77 Lumens Per Watt (Initial) . ANSI Binning: + / - 175k MacAdam Ellipse: 7-Step CFL Equivalent: 18W per EngineDimmability: Down to 5 percent Beam Angle: 120 Ambient Temperature Operating Range: -20C to +40C ( -4F to +10F) . EPA Compliant - 6,000 initial total lumens, the equivalent of six 75 watt incandescent bulbs Justice Design Group - FAL-9614-35-DBRZ-LED6-6000
LumenAria 36-Inch 6000 Lumen LED Semi-Flush Mount with U-Clips Review
Great product once again from Justice Design Group. I was immediately able to use my LumenAria 36-Inch 6000 Lumen LED Semi-Flush Mount with U-Clips for my work.
