UL Listed Resistor Power Bank with Power Check
With a slim design the UL Certified Resistor Power Bank with Power Check gives you the added power you need without the added weight. With a 4,000 mAh Grade A Lithium Polymer battery and a 5V/1A output you can charge your smartphone at the same rate as most wall outlets. The power check display tells you exactly how much power is left in the battery backup. Includes a USB to Micro USB connecting cable which can recharge the battery backup or be used to charge up devices with a Micro USB input like Android Smartphones from Samsung, Motorola, HTC, Nokia, and others. This product has passed UL standards. Material: Aluminum. Manufactured By Leeds.
UL Listed Resistor Power Bank with Power Check Review
Great durability of the products. I would buy UL Listed Resistor Power Bank with Power Check again!
